Fully charged Samsung PL55 emits 3 low frequency then dies.
AS stated above, have looked at battery, is fully functional, and the camera was not subject to impact.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
as far as i could goolge it - the main problem with the 3 beeps was a dropped camera - the lens got a little bit tilted and thats why the camera beeps and switches off.
but since i don't have one of those cameras, i can't reproduce the problem.
is there somethin on the screen before it starts to beep ?
does the cmaera makes any noises arount the lens ?
could you try to wiggle the lens a little bit after you witched on?
Bu yanıt yardımcı oldu mu?
I giggled the lens some after noticing a tilt....I LOVE YOU...well not really, but I am very grateful since you solved the problem!!!
WIll you accept his answer? Then other people will know to look here for a solution :)
I have a SAMSUNG PL55 digital camera. It fall with the lens open and and the lens doesn't go back. It was stuck. I opened it and I directly feed the lens motor with 5V directly from an AC/DC adaptador (the battery is 3,7V). The adaptor I get in home has the closest voltage I could get. When I feed the motor the lens with the properly polarity the lens go back and so I saw that apparently everything (mechanical part no jammed) was okay with the motor and the lens. But when I put the battery and and power on normally the lens go forward and the 3 or 4 beeps issued and the lens can go back. What can be wrong? I let the battery charging 100% just to be sure then I tried and the problem persists...maybe something wrong with the electronic sector that commands the lens motor?!?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,202
