Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
442 Soru Tümünü görüntüle
Battery not powering Mac, New Battery, New Power Logic Cable.
Hi,
i have replaced the Battery, and Logic board battery cable, computer still only works with the AC, turns off IMMEDIATELY after AC is removed... is the next step a new logic board??? $600 question....
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Help us help you. The more we know for certain the more help we can be.
The trigger that caused you to decide to replace the battery and logic board cable certainly can could be the reason why the machine suddenly shuts down after the AC power supply is disconnected.
If there was a liquid spill it would not be out of line to replace a damaged logic board, and a liquid spill could cause the problem you're having. So might a power surge.
Examine the logic board under a magnifier… look closely for burn marks, corrosion or swollen components. If you find some that would indicate a logic board replacement… DIY component replacement requires special tools, solder and lots & lots of practice… it's nothing like soldering a lamp cord.
If this answer is acceptable please remember to return and mark it.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
logan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 101
