Ana içeriğe geç
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
942 Soru Tümünü görüntüle
MacBook doesn't power up
Hello
I replaced the trackpad of the MacBook Pro 13". Now the Laptop will not powerup with the switch on the KeyBoard.
Because the MacBook works fine till now. My Question? Is it possible to switch the mac on with a shorten direct on the logicboard. In the past some mac has such a layout that you could start it with a screwdriver. I can't find it.
The Logicboard has the part 820-2530
Can someone help me?
Regards
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Recheck the cam was unlocked before your inserted the ribbon cable and you inserted it right side up and far enough in and locked the cam down afterward. Recheck the top case ribbon cable connector block - that it's square and fully clicked in.
If those are ok you'll find thaton more recent models they stopped with the pads - from the ribbon cable connector block you have to '''short short pin 5 to pin 29 or ground'''.
If this Answer is helpful please remember to return and mark it Accepted.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorumlar:
Hallo machead3
After disconnect the cam-cable an reconnect the cam-cable I was able to start the mac with shorten the logic board
On the logic board of the MacBook Pro (13-inch, Mid 2009), there are two pads that can
be shorted to power on the system. These pads are located above the trackpad flex cable connector and below the hard drive flex cable connector. The power-on pads are shiny, silver, square, and larger than the other (mostly round) silver pads nearby.
Now I see the keyboard works only on the right part, but not all the key (no delete-key). The replaced trackpad now works.
I refit the keyboard ribbon cable out of its socket a couple of times but this has no impact. Either the keyboard is broken. The ribbon cable is fit as max in the socket.
Any Idea?
tarafından
Yorum Ekle
Yanıtını ekle
Gerard Dirks sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 645
