Ana içeriğe geç
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
151 Soru Tümünü görüntüle
Ipad 2 touch flex cable removal
I just ordered a new screen, how ever I only got the glass there is no flex cables off it for the touch assembly. Is there a way to take the old touch flex off and place it on the new glass with out damaging it. And if so how do I do it... Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It will be a very long process but it is possible if old touch screen is working. You can use a heat gun to separate old broken glass from your digitizer. Not easy. You can use heat gun (or hair dryer) and a business card to separate digitizer (lot of videos on youtube. Search glass separation and LOCA). After that you need isopropyl alcohol cleaning on digitizer. After cleaning you can use LOCA glue to put glass and digitizer together. You need to do it with a good angle (without air bubbles).
But i recommend you to buy a glass digitizer assembly for $20. Since loca glue will cost you same thing I guess.
Good luck ...
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Michael sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 92
