Ana içeriğe geç
The Black N Decker Toast R Oven TRO200 is a 4 slice under counter toaster oven with bake and toasting capabilities.
on/off button for toaster doesn't stay on
The on/off button for the my under the cabinet B&D toaster oven will not stay on. The oven part of the unit works fine. I see that the button can be replaced, but where do I get a replacement button?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I couldn't find a replacement oem button for the toaster, you can go to radioshack and pick up a toggle switch and try that or buy a new toaster. Sorry
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
I have the same unit, I carefully, with a pair of pliers, adjusted the magnet so it aligned better with the switch mechanism.
It has been ok for me.
tarafından
Where is magnet and how did you access it? Do I have to remove cover?
tarafından
Magnet is same side as button and should stick to a little transformer ( 2 red wires from bread board). Just take the right side off and adjust the plate connected to button so it is flush when pushed in.
tarafından
Yorum Ekle
Yanıtını ekle
Linda Landrigan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 1,867
