Ana içeriğe geç
The Nintendo Wii U Pro Controller is a video game controller produced by Nintendo in 2012 for the Wii U video game console.
25 Soru Tümünü görüntüle
Wii U Pro Controller Not Working
Okay so I've had a wii u pro controller for over a month, and its been working fine. Until an hour ago, when the wii u console froze, I had to unplug the console and replug it into the power outlet. When I turned the wii back on, the wii u pro controller stopped working. Although the wii u gamepad worked perfectly. It would still show a red light to indicate that it is charging, but I click a button on the controller and the 4 blue lights don't come on(like they usually do). So please can someone help me.
Update (01/02/2014)
#1 yes
#2 no
#3 yes
blue light battery level
red-charging
Problem is, only light on is red(won't work, tried charging, nothing happened)
Bu iyi bir soru mu?
Puan 10
15 Yorum
How do you do it how do you fix if it happens the samething happened to me
tarafından
My controller has the same problem, it says it's fully charged and syncs and turns on fine on the home screen. But as soon as I resume the game it unsyncs and turns off
tarafından
I have the same problem right now. Did you fix it?
tarafından
i have the same problem only it keeps me from using all controllers and wii motes except for the gamepad which works fine. but i had 6 controllers working fine now none of them work ever.. and i even did a step by step walkthrough with a Nintendo Technician and because it froze everytime after using the wii u system settings, he said the issue seems to be software, which then claimed i needed to pay 100dollars + shipping and handling to get it fixed, which is like nearly the price for a new system. isnt there a way to use my controllers again without paying nearly the same amount as it would be getting a brand new wii U
tarafından
i had quite an Annoying Problem with my Afterglow Controller, everytime someone pushed a button, the WiiU powered off.
But after resynchronizing it with the WiiU, it returned to working normally.
tarafından
10 tane daha yorum göster
Yorum Ekle
10 Cevap
Filtre ölçütü:
Seçilen Çözüm
There is a small hole on the back, to the right of the sync button and a visible screw.
Use a pin or something to press it in for like 10sec - it will reset the controller. Worked for me.
Bu yanıt yardımcı oldu mu?
Puan 8
5 Yorum:
I have an afterglow and it looks a little different, but I tried this trick, and it won't work for me. Anyone know the awncer?
tarafından
I think this a dead forum.
tarafından
i tried this like a million times. and i think it just resents the battery too
tarafından
Worked like a charm!
tarafından
The control just froze, i did that and it worked!!! Thank you so much!
tarafından
Yorum Ekle
A bit more info please?
- Have you charged it completely?
- If you press the SYNC button the the back, can another Bluetooth capable device (such as a PC or sometimes a phone) recognize the controller?
- Have you pressed the SYNC button on the controller followed by pressing it on the Wii U as well to see if it can connect?
Some statements:
- The RED light indicates a drained or low battery. The ORANGE light indicates that the controller is charging.
- I don't think that the Wii U Pro Controller can indicate it's battery level with its four blue LED's (I might be wrong...)
Puan 2
4 Yorum:
Yes i pressed the SYNC botton it didnt work
tarafından
1. Press the Synchro-Button on the Controller, so that it blinks.
2. Press the red Synchro-Button on the WiiU, so that it pairs again.
This Method worked, when my Afterglow-Controller turned my WiiU off, everytime someone tried to use it.
tarafından
1 of my pro controllers wont even blink not charging nor syncing my other 1 does charge and blinks yet dosent sync but my wii u remote still works i wonder why?
tarafından
My charging light works fine, it's just that when i hit the synnc button nothing happens.. i just got my controller and this is happened
tarafından
Yorum Ekle
When you push a button on a Wii-/WiiU-Controller, the 4 LEDs, used to show what player you are, tend to flash, indicating how much the Battery is charged.
Puan 1
Yorum Ekle
Did you have a non nintendo screen protector on? We bought an "icon" brand screen protector. It worked at first the first couple days we had the Wii. The next day, the gamepad became completely unresponsive. After we tried what other people said, which was take the battery out. It worked a little bit. but the screen was jittering back and forth, we couldn't click on anything. Some of the buttons worked again but not all. after troubleshooting for 4 hours, we finally decided to take off the icon screen cover. WOW! Now it works perfectly. My husband had read that nintendo said other screen covers could mess up the Gamepad, and they weren't kidding.
Puan 0
1 Yorum:
My suggestion is if you have anything non Nintendo, to stop using it and take it back.
tarafından
Yorum Ekle
I had the same issue. What I found to be the fix after calling Nintendo was to turn the Wii U console on before the game pad'. As goofy as it sounds, this was my fix.
Hopefully that helps.
Puan 0
Yorum Ekle
You just need to reset your controller I had the same problem but then I reset my controller
Puan 0
1 Yorum:
how reset controller??
tarafından
Yorum Ekle
Is there an orange light and does it show it is charging. If so, charge it then wait until the battery finishes then press a button and it will work. It takes a long time to finish the battery. I have an afterglow pro controller and the same thing happened. I waited and it worked, I hope this will work for you as well.
Puan 0
Yorum Ekle
take a pin, hit the reset button on the back of the controller. then re hit the sync button on your wii u then rehit the sync button on the back of the controller . should fix your problum.
Puan 0
1 Yorum:
what reset button?
tarafından
Yorum Ekle
my controller is not turning on no matter how much icharge it.
so i went to eb games to fix it
Puan 0
1 Yorum:
what i eb games?
tarafından
Yorum Ekle
My wii u pro controller (black) charges fine, displaying a orange light and it (the light) times out after 25-30 minutes.
When I hit the sync button, nothing happens. The controller stays in a normal state.
There are 3 things on the back of my controller: a sync button, a screw and a hole (about the same size as the sync button, slightly smaller)
I’ve watched 3 videos and seen 2 forums and apparently nobody I’ve seen has this problem.
I tried to use Nintendo’s forums, but for some reason it keeps on saying ‘the link you used to access this page is no longer valid’ despite using it 1-2 minutes after the link was sent (it said 24 hours max) so I had to find something new.
Could you please tell me what my problem is? I’ve tried most of the things that you’ve used but they don’t work.
Puan 0
Yorum Ekle
Yanıtını ekle
jeff vue sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 25
Son 30 gün: 85
Her zaman: 47,005
