MacBook Air models with 13" displays
2178 Soru Tümünü görüntüle
LED Backlight not working reson water inside
my macbook air led backlight not working bacause some water get inside of my macbook.
what i do i think its fuse problem how can i solve and from where i buy components
thanks
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You should read through the tags at right to know what you're in for, & what can happen if do not stop attempting to use a wet machine, do dissconnect all power and clean the logic board.
Only by examining the board can you determine how badly it's damaged, what other components are lilly to go bad over time without attention.
Start with obtaining the proper tools (every job is easier if you use the right tools). Study (not just read the guide and comments for your particular machine (13" MBA is a very generic ID).
You probably have damaged the controller/fuse for a LED display version MBA… or you may have less complicated, expensive damage on an older model.
If this answer is acceptable please remember to return and mark it.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
parminder sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 110
