Broken display port to logic board
Removing LCD pulled out too far & broke connection to display port & logic board can this be fixed ?? (8 GB ram Radeon HD 4850 512 mb)
Bu iyi bir soru mu?
Bu iyi bir soru mu?
As Oldturkey03 said computer logic board soldering is not for amateurs - its' easy to destroy the multilayer board. You need special tools, solder and lots and lots of practice.
A small electronics/computer repair shop could do this. You might be able to bring them the logic board and reassemble it as your part of the DIY (but with your lack of success so far it's a very daunting task.) Logic board removal/replacement requires diassembling and reassembling the entire machine - perhaps you should bring the machine to a shop and let them do it.
If this answer is acceptable please remember to return and mark it.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 402
1 Yorum
Butch Sullivan, let us see what you see. To give it a good try to answer your question, it will help if you post an image of your damage. Use this guide to add images. This repair may require soldering on the board. Please make sure that you have good tools and soldering skills before attempting this. If you do not have those skills yet, either practice or consider having someone fix it for you. Again, post an images so we can see what you see. Also, post the last three digits of your serial number so we can properly identify your computer and your logic board.
oldturkey03 tarafından
