Ana içeriğe geç
Fan noise on startup for at least 5 minutes
Every day when I'm starting working on my laptop, fan (I think it's left fan) is noising for at least 5 minutes. After that it's working quietly.
I've recorded the noise, you can listen it here https://soundcloud.com/pavlentij/macbook...
Should I replace the fan or it can be fixed with oil? If it's not fixable then how I can discover which one fan is noising?
Thanks.
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I would not put oil on a fan. The fans can be replaced (study the guide and comments before doing so).
A fan app will tell you which fan is running at high speed.
Perhaps all you need to do is clean off some dust. I would (try that first). After you've cleaned the inside you do not have to completely reassemble the machine to test it and see if the problem was solved...
If this answer is acceptable please remember to return and mark it.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Pasha Tkachenko sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 370
