Will not boot or turn on
My magsafe lights green but when I depress the power button nothing happens tried SMC reset to no avail. Can this be a bad battery, or would it boot by A/C even with bad batter. Any suggestions.
Bu iyi bir soru mu?
İptal Et
2.26 or 2.4 GHz / White plastic unibody enclosure
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz AtınTake off the mains and remove the battery overnight. Reinstall battery, then mains, then try boot.
If this answer is acceptable please remember to return and mark it.
Yorumlar:
I tried a jump start w/o battery and it worked , after jump start I connected keyboard ribbon and the keyboard is working. Performing a back up now, happy it started but not sure what to do now re: diagnosing and fixing the problem.
DPWCT tarafından
no battery test button on A1342
DPWCT tarafından
Connecting while powered very risky I'd say you'll have to replace the top case… a standard DIY fix for your sort of probem.
originalmachead tarafından
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 164
When you press the battery test button, what does it show?
mayer tarafından
