I have a question about the hard drive replacement guide instructions
On step 10 of the hard drive replacement guide, it says "Before disconnecting the thermal sensor cable, take note of its orientation. It is extremely important to reinstall the connector reversed from the current orientation so the fans will not run at full speed."
To me that says the thermal sensor cable should be replaced in the opposite orientation than when we removed the cable. It seems counterintuitive to replace it opposite the way I found it.
Am I misunderstanding the instruction? Or should I really flip the orientation when I re-install? The replacement drive is on order so I've got a few days before I'll be reinstalling.
Thanks.
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Devil is in the details read the notes too!
Some drives will be like OEM drives (there were none in 09) some drives are still not OEM compatible.
If this answer is acceptable please remember to return and mark it.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Stanton Macfarlane sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 130
