My laptop freefe after the ignition
my laptop freezes after a few minutes after the ignition. the screen freezes and nothing be working. my only alternative is a forced extinction.
can someone help me? thank you.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
You probably have a failed or failing HD. Constanly crashing the machine is not helping. Crashing leads to more HD issues. Boot from another source (install or repair optical disk) run DiskTools to repair your HD. If repair fails there's your problem.
If this answer is acceptable please remember to return and mark it.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 86
2 Yorum
I just replaced the hard because I had this problem with the old.
I een prifité to make a dusting, the problem persists.
bad day.
edwoob tarafından
If the replacement drive was used… it can be failing too. It could be your connector (connection) check the drive is correctly seated - not one pin misaligned.
originalmachead tarafından
