Ana içeriğe geç
A 15" Apple Studio Display released July 19, 2000, identified by model number M2454.
2 Soru Tümünü görüntüle
How to tighten stand on display
I recently replaced the hinge on my display. Now the stand is loose and will not allow the monitor to be a different angles. I can not find a manual anywhere.
Thanks.
Rosemary
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Check out my link here. Ralph
http://docs.google.com/viewer?a=v&q=cach...
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
nice link +
tarafından
Looks like this link is dead. I too would appreciate any insight into a replacement hinge / mounting plate / bracket.
tarafından
Yorum Ekle
Where did you find the hinge? I need to replace mine.
Puan 0
Yorum Ekle
A friend gave me the 20" version of this monitor over the summer with the same issue. I thought I could find a replacement hinge on ebay or other secondary market. No luck. They were either for the wrong size or too expensive.
I had the thought of putting it in a fixed position by tapping it with a screw, but it is not made like that. Where I thought I could tap is only plastic. No luck, but a thought. Reverse it.
I turned the hinge around. You need to slide the ferrite filter to the other side. There are three index marks that will need to be filed down. Screw it back down and replace the cover and stand.
It now seats on my desk at little greater than 90°s, no slide. Gravity should keep it from coming forward.
Ok, I could have tried to set it as it was by tightening the nuts on the ends of the hinge. But I could have over tightened (not mentioned in the manual) and snapped them off and/or it might still be loose.
Puan 0
Yorum Ekle
Yanıtını ekle
Rosemary sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 2,326
