Ana içeriğe geç
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Soru Tümünü görüntüle
MacBook doesn't turn on
Hello guys!!
I removed the fan of my Macbook, cleaned it and put in the same place.
After close the Mac, and press the power button, the Mac work but don't recognized the keyboard.
I switched off the mac and press the power button again.
The macbook doesn't turn on anymore!
The magsafe adapter works fine.
I don't know that to do!
Somebody have an idea to fix it?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Thank You for answer! After I see a video in youtube, I touch the board connectors of the keyboard with a screwdriver and the Macbook turns on!!
I think that the flat cable of the upper case is damaged. It seems very bent.
I put the connection of the upper case in the board very very times, and it doesn't work.
Can it be other thing?
Now I'm using a Wireless Keyboard, until I know exactly what I have to change in the macbook.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Without seeing the connector I can't say for absolute sure but it wouldn't surprise me if you were right in that the top case's flat cable is damaged/faulty. They are fairly easy to damage the first few times you do the repair if you don't take care to disconnect it before lifting the top case up too far.
Technically it "could" be the connection on the logic board, where the top case connects, but out of a 1000+ MacBook repairs I've only seen this occur one or twice. A new top case (iFixit calls them upper cases) is much more likely the culprit, replacing that should get you back up and running. (also, as a heads up, when replying to an answer you want to do so as a comment, rather than as a new answer)
tarafından
Yorum Ekle
En Yararlı Yanıt
More than likely the top case connection isn't seated properly. I would disassemble it again and make sure to push this connection in until it feels solid. It's a bit awkward to do the first few times so I wouldn't doubt that it might be loose if you haven't removed the top case a few times.
Step 12 in this guide shows the cable I speak of.
Before re-assembling the Mac I would try to power it on, just to make sure it works before you reinstall all of the screws.
Puan 3
Yorum Ekle
Yanıtını ekle
Joao Conttroller sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 309
