Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
481 Soru Tümünü görüntüle
iMac 24" USB boot up and crashes at installation
Ok I got a 2nd hand imac 24 - 2211 - A1225
I can usb boot with multiple OS X retail versions. I can go to disk utility and partition hard drive read usb contents and see super drive all day long with no problems. Once I click install, it will start analyzing. it will say 30 mins. Then boom immediately black screen. I have to hold power button to reboot it.
What is the cause of this?
Thank You
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Use at least system 10.5.2 DVD. Boot from it and use Disk Utilities to reformat the drive with the "write zeros" option. Next partition it and use the GUID partition option. Now see if it will take a system. Let us know if it works.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorumlar:
Hey mayer, thanks for the input. but what I came to find out was that the imac was firmware locked. figured that out because I could not boot into safe mode or use any of the option/command buttons at start up. so I read up and found that I had put a password years ago and forgot. so I did the ram trick and got the os x to install finally.
thank you
tarafından
ok new problem, I can install snow leopard 10.6 and runs fine. once I install updates I get white screen and doesn't boot anymore. I try fresh/clean installing mountain lion 10.8.3. it installs but then blank screens during install. every so often when I force shutdown and power up. it will go to intall screen but then it will flicker at home page and white screen.
what am I doing wrong?
tarafından
Yorum Ekle
Yanıtını ekle
chillfactr sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 2
Her zaman: 325
