My toyota camry ac is not cooling but the fan runs
how do i fix my air condition
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Have you tried cleaning the condenser on it. This is the radiator looking thing that sits in front of your radiator and is how it releases the heat. Just spray with the water house from the back side to the front {from the engine side} be sure not to have a lot of pressure you will bend the coil fins. You can also rinse the front of it off by looking through your front grill you will see the coil clean off any bugs and debris that may block air flow. If still not cooling go to Wal Mart get s can of the 134A recharge for A/C {the one that has a gage} follow the directions for charging but make sure not to over charge. You don't want the pressure to go above 25-30 psi when at idle.. Good luck
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 1,278
