Is there any recouse for broken zif socket for keyboard backlight?
ZIF socket is broken. Is there a repair short of motherboard replacement?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
If the socket is still attached to the logic board you can "McGyver" something. Try to secure the cable with tape or glue but be ultra careful not to break more or shorten something.
Bu yanıt yardımcı oldu mu?
This also happened to me. Before I discovered ifixit.com, instead of pulling the ribbon AWAY from the socket, I pulled the ribbon AND the socket out away from the board. Those solder points are way too small to be resoldered back on. So I just live without the backlit keyboard. That is unless someone here can find a way to reattach it.
This is a 4 pin connector, i believe only two are connected.
Can anyone post me a good close up photo or test where those go
and i will come up with a fix.
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 3,709
5 Yorum
I think it's completely off and the cable is loose. I will try the MacGuyver method. Need to look at iFixit pics a little more for position. Thanks.
Mark Cleary tarafından
How broken is broken ?
is it completele teared off or what happend with the socket ?
markus weiher tarafından
Hey
Did you manage to solve the problem?? I have the exact same problem and
my ribbon cable refuses to go in.
Thanks
RiceJunkie tarafından
just wondering whether you'd done a search on google or ebay for the zif part? you may be able to find someone who sells them and then resolder it back on..
pollytintop tarafından
I have and it doesnt seem to be an easy find. plus soldering that thing back on is not your typical soldering job.
It is a very poor design.
