Ana içeriğe geç
check engine light still on small leak in evap system?
Auto zone turned check engine light off but came back on. It said there was a leak in the EVAP system. Gone unfixed, will that cause problems later on and how much does it cost to have it fixed??
Bu iyi bir soru mu?
Puan 2
2 Yorum
I should've said that I did replace the gas cap with a brand new one but it didn't help. A mechanic told me regarding EVAP check would entail blowing smoke or fog into it but may not even show leak then. I live in fla. so we don't have to have an emission sticker. Anyone have a ball-park cost to do the fogging it and to fix it?
tarafından
Did you get the OBD scanned and do you have the code?
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
I know this is an old question but it really wasn’t answered so here goes . Smoking the evap system will take less than an hour or time so depending on the shop rate you have an hour of labor and whatever part need to be replaced . It can be as pricey as a evap valve set that can be 2-3 hundred dollars to a vacuum hose that would probably cost a dollar or less if the mechanic is nice . To the other part of the question will it effect the car the answer is a bit tricky . For the most part no but there is the possibility it can vapor lock the tank which can make the flow of fuel difficult but thats usually when the gas cap is bad . Seeing that you replaced your cap this wouldn’t be an issue other than the annoying MIL light . I would suggest having the codes read occasionally. Seeing how the light will be on all the time you wont know when another issue may occur that could actually be detrimental to the car Hope this helps
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Vicki, check the gas cap first. Insure the gasket on the cap is not cracked, and if so, replace the entire cap. Get the cap at Auto Zone, as the dealer price is too high, and an aftermarket cap is very reliable. There are only so many connections in the vapor recovery system, so it should be fairly easy and not too expensive to have the dealer check it out. The EVAP system is a California regulation, and if that check engine light is on when you go to have it SMOG'd, you won't pass.
Puan 0
2 Yorum:
Gas Cap Fixed It For Me.
Check engine light gone.
tarafından
What is OBD code?? I'm not too mechanically inclined??Can't spell too good today either. The guy used some little gadget to check it, then told me it said "leak in evap system"
That's really all I know. He didn't tell the actual code.
tarafından
Yorum Ekle
It usually the charcoal vapor canister. Its supposed to absorb extra gas vapor for emissions reasons. When the charcoal breaks down it no longer absorbs vapors so the computer turns on your check engine light because it is no longer emissions compliant. Its a pricey part at ~$300, however it takes less than 10 minutes to replace.
Puan 0
Yorum Ekle
Yanıtını ekle
Vicki Valdez sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 38
Her zaman: 6,144
