Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
860 Soru Tümünü görüntüle
Why is it not starting up?
It goes to the Apple logo for a sec or two, the clicks, and then shows a red circle with a cross inside, and underneath in white "www.apple.com/support/ipod". I guess it's the hard drive, or the hard drive cable, or the logic board. This started happening when I tried to restore the iPod after it had been sitting for a while—it thought it was full, but only with "Other". Any ideas how to narrow it down?
Thanks!
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
ashik, you already narrowed it down. " the clicks," that is your hard drive not working. This can be because of a few reason. Number one being the drive itself. Get a USB to Zif adapter for something like $5 on ebay and see if you can access your drive without the iPod. The other possibility is a bad battery. If you have not enough power on your battery it can not spin up the drive and registers it as a failed drive. So replace the battery as well. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
ashik sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 106
