Ana içeriğe geç
Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
552 Soru Tümünü görüntüle
I CANNOT remove these screws!? HELP
I just got my new macbook pro. I want to remove the screws to upgrade the memory and there's just no possible way to remove these screws.
I made several trips to Home Depot and tried every variation of the small screwdrivers.
I've tried the Phillips #00 and the 2mm phillis and torx. I've tried 2.4 mm also. NOTHING WORKS!!
It's driving me mad. I'm pretty sure one is now stripped.
Has anyone removed these screws successfully? What tool did you use?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Just give up. U can't upgrade the memory anyway
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
They're called pentalobe screws and require this driver: P5 Pentalobe Screwdriver Retina MacBook Pro and Air
Tom is correct, you cannot upgrade the RAM. Always read up on the guides or the teardown before attempting to work on anything.
P5 Pentalobe Screwdriver Retina MacBook Pro and Air Görseli
Ürün
$5.99
Puan 2
1 Yorum:
The P5 Does not work for mackbook Air you will need a P4
http://www.kctoolco.com/Wiha-26764-Preci...
tarafından
Yorum Ekle
you are both right . but i like the first answer . just give up no ram upgrade .
check everymac.com before looking for screw driver :)
Puan 0
Yorum Ekle
Yanıtını ekle
Omar Elbaga sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 488
