Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazı tamir ederken daha önceki modellerde kullanılan aynı tornavida ve plastik açma araçları gereklidir. GSM/CDMA olarak, 16,32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renkli modelleri mevcuttur.
3789 Soru Tümünü görüntüle
iPhone 5s's battery with separate charger flex.
Due to persistent problem with iPhone 5s's battery - don't you plan to make your own flex tray with integrated charger ?
It can be even, probably, with micro-usb connector )
My 5s has lot of problem with charging.
I replaced battery, but it hot like !@#$ now (
And there are no proofed solution for me (
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorumlar:
What are you talking about?
tarafından
Battery was replaced already - phone still hot and discharging very quickly.
Dock connector is on the way from eBay.
I think it can be connected with it because looks like phone frying any cable connected to it - all of them stopped working after a time - and starting write "Accessory not supported" - first one died my original cable which come with phone.
Unfortunately - I did not found any service here - in Russia for free (
If it's a charging circuit on the logic board - it'll cost about $200 - $300 to repair it here.
I'm very disappointed in Apple quality now...
It's my first and last iPhone I guess ...
I bought top model of Apple iPhone (5s with 64GB) not for such service surely...
tarafından
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Alex Tches, sounds like your 5S is not charging and you are looking for an external charger. No external chargers are available. Sounds like you are also saying that your battery is getting hot. The phone should still be covered under warranty, so try to get it repaired/replaced that way. Otherwise, this could be caused by a defective battery, a bad dock connector or a bad charging circuit on the logic board. I'd start with a battery, but only if the phone is not covered under some reason by warranty. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Alex Tches sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 131
