Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
824 Soru Tümünü görüntüle
If this machine can run 16gb of ram are there any drawbacks?
I am running 8gb of ram on a late 2010 17" 2.53 i5 last 4 of serial number are DC7C
After reading the posts I would very much like to upgrade to 16gb of crucial memory! But I was told by a tech at apple that even if the 16gb of memory booted up the system may only use half of the available memory because of the 8gb limit. After reading your posts I wonder if they were just reciting the tech specs because they want to sell new models not enable older models to be upgraded beyond the specs that were published at the time. It seems you can answer this question!
I am a photographer running photoshop and this laptop experiences big slowdowns and freezes when I am editing large photos. Saving the photos while editing doesn't always help. I plan on upgrading to mavricks after I update all software possible and do a full time machine backup. If this machine can run 16gb of ram are there any drawbacks? Potential problems? As this is my workhorse when I am on location I don't want to lose it. Thank you in advance!!
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sorry to say your system is a transition system which had a limited controller logic Intel's first controller for the new i series CPU's could only support 8 GB of RAM. The Early 2011 systems are the first that support 16 GB of RAM with an updated controller.
Update
I would strongly recommend you check your EFI firmware Apple TN I would also recommend you upgrade your HD to a SSHD (hybrid) and larger drive. split the drive into two volumes (equal size) using the second volume to hold your images.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Josiah Reed sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 2
Her zaman: 333
