Ana içeriğe geç
Model A1103 / 1.25, 1.33, 1.42, or 1.5 GHz G4 processor
62 Soru Tümünü görüntüle
CD stuck inside the unit. Help?
I have a mac mini as listed A1103 it belongs to my girl theres a cd inside the unit and it doesnt come out and seems to be causing some kind of error because the unit doesnt post. Is the cd inside causing the problem, in any case this is the issue how do i take the cd out?
Or do i have to replace the optical drive?
Thanks in advance.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Restart holding down the mouse button and it should eject.
Also try:
Open the Terminal in the /Applications/Utilities/ folder and run:
drutil eject
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
thanx let me try that now! im not very talented with macs. I work for HP maybe thats the answer but thanks!! another quick question..that is causing the problem of being unable to start up?
tarafından
Let's get the CD out and see what it looks like. The unit may boot fine. If not let us know and we'll diagnose further.
tarafından
Yorum Ekle
If your CD is stuck and none of the other methods work, you might eventually try pulling out your optical drive and doing this: Optical Drive Disc Removal Technique
Puan 1
Yorum Ekle
You could also try the
double sticky tape trick,
There's many reasons to fail POST however AFAIK a stuck CD is not one of them.
Puan 0
Yorum Ekle
Yanıtını ekle
Ramon Aviles sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 3,379
