Ana içeriğe geç
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Soru Tümünü görüntüle
Trouble playing a dvd - there's sound but no visual?
My mac (bought only a month ago) was playing dvds perfectly until today when I shifted it on my lap. Then it started to have trouble. Now whenever I play a dvd it plays as normal (with sound, the timing bar continues to play) but with a black screen. There's no visual whatsoever. Any help would be great!
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
I would try to reset the pram and smc first (even if it might not be 100% nescessary - it would rule some settings issues out)
PRAM and NVRAM reset:
1. Shut down the computer.
2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
3. Turn on the computer.
4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
6. Release the keys.
SMC reset:
2. Plug in the MagSafe power adapter to a power source, connecting it to the Mac if its not already connected.
3. On the built-in keyboard, press the (left side) Shift-Control-Option keys and the power button at the same time.
4. Release all the keys and the power button at the same time.
5. Press the power button to turn on the computer.
Note: The LED on the MagSafe power adapter does not change states or temporarily turn-off when you reset the SMC.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
I had this problem with my Macbook running 10.6.8, audio okay but nothing visible except a black screen. The SMC reset was all that was needed to bring things back to normal.
Thanks!
Puan 0
Yorum Ekle
I've tried resetting both the NVRAM and the SMC on my 2013 MBP 13", and have been unable to get video/ from a DVD to show (using DVD player). Three has to be an answer.
Puan 0
Yorum Ekle
Yanıtını ekle
victoriaT sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 45,447
