I need a diagram of how to put belt on mower
I need a diagram of how to put belt on murray select model 425000x8
Bu iyi bir soru mu?
Bu iyi bir soru mu?
i've googled the cache of a "crappy paysite"
but here is the thing you need:
http://www.outdoordistributors.com/pdf/M...
and this is the text from the site:
"See attached link and go to page 7. It is going to make it quite a bit easier if you take the mower deck off. It will come off by removing some pins at the mounts. Once you have the deck off you will need to push the clutch in to give you enough slack to get the belt off of the engine pulley. If the belt is blocked by a belt guide that is attached solid to the frame you will need to remove the center bolt out of the pulley and slide it down on the crankshaft.Once you have the belt off of the front pulley you will just remove it from the rear pulley and idler."
i hope this helps
Bu yanıt yardımcı oldu mu?
good +
That link gives a "404 error"
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 3,399
