Ana içeriğe geç
iPhone'un 5. jenerasyonu. Cihazın onarımı basittir; tornavidalar, kanırtma aletleri ve sabır gerektirir. GSM/CDMA / 16, 32 ya da 64 GB / Siyah ya da Beyaz.
2193 Soru Tümünü görüntüle
The volume buttons won't work one my iPhone 4s
when i click the volume buttons, the screen just says ringer, the sound doesn't work for spotify, youtube, and it's doesn't ding for texts or notifications, but if i set up an alarm, or go into setting and mess with the sounds and alerts bar, the sound works. i don't know what's going on and i need help!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Be sure your phone has been currently updated
Is your phone in silent mode? Check the side of the phone where the vibrate/silent button is located. Also be sure to go over your settings as well to ensure everything is set up correctly
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I have had this problem before usually means the iPhone is in docking mode and would need a replacement dock connector.
Before replacing this part try cleaning the port with an unused tooth brush and some pure alcohol.
Hope this helps :)
Puan 1
Yorum Ekle
I'm having the same problem thinks its got to do with the new iOS on iPhone 4s
Puan 0
Yorum Ekle
I normally isn't a problem with the IOS. Clean out the charging dock with a clean toothbrush, there should be no need to use rubbing alcohol. That is what worked for me.
Good luck!!
Puan 0
Yorum Ekle
Yanıtını ekle
jade sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 7,214
