Ana içeriğe geç
Apple's line of MacBook Pro laptops was intended for the professional and power users. The MacBook Pro line includes the MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17", and the MacBook Pro 17" Unibody.
15119 Soru Tümünü görüntüle
How do I isolate the problem with my logic board?
I have a 2006 macbook pro, and over the many years it slowly started to overheat until the typical GPU problem kicked in and the screen became fractured and the computer unusable. I baked the logic board, and it worked again, but only for a couple of months before the same problem repeated.
So I baked it again, applied Arctic Silver 5 thermal compound, and upon turning it on again, the hard drive would make mounting sounds and within 5 seconds the fans would be going at full speed, but nothing more. The display would show nothing and I would hear no chime.
I figured the board had had it, so I ordered a replacement from a 99.7% rated seller on ebay with tens of thousands of feedback points.
Upon installing the new one, I turned it on and had the same result. No display, no post, and high speed fans.
So now I am thinking that either this logic board is a dud too and I need another replacement, or that there is something else wrong with my computer other than the board.
Problem is, I can't imagine what else it could be.
Does anybody have any advice for me?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
MacBook Pil Tamir Setleri
Başlangıç $69.99
Buy Now
Başlangıç $69.99
Buy Now
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Recheck all your connections - logic board swaps/removals are major projects. If you have damaged cables or connections the behavior you describe would result.
After you're 100% sure things are right on your end, talk with your vendor… the logic boards are recycled and damage could have occurred at removal.
If this answer is acceptable please remember to return and mark it.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
noah sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 99
