Ipad mini Backlight comes on briefly at power on then shuts off
So I have this iPad Mini with the well known no backlight problem. In this case, the backlight comes on fine while the unit is charging, but as soon as it begins the boot process, it goes dark.
I'm wondering what component might be causing this fault. I don't believe it is the fuse because as far as I know, I would see no backlight at all.
What other components could be the culprit? And has anyone seen these particular symptoms before?
Thank you.
Bu iyi bir soru mu?
1 Yorum
Did you ever solve this? I have the exact same issue. Replaced digitizer, now backlight comes on for a sec then turns off. The ipad continues to boot normally. Every time I reboot the backlight comes on for a moment, though.
Steven Wallis tarafından
