Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB DDR5 Video RAM
431 Soru Tümünü görüntüle
Why SSD runs at low speed in the optibay?
Hello!
I've installed your upgrade kit. And now there is a problem. SSD was installed in Optibay and used as the main drive for OS X. His speed read / write is only 250MB. Why such a low rate? in the information about the system shows that the drive is connected to the speed 6GB. (sata III)
MacBook Pro 15 "Unibody Mid 2012
256 GB Solid State Drive
Unibody Laptop Dual Drive
Thanks for your help!
Unibody Laptop Dual Drive Resmi
Ürün
$24,99
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
SSD read speeds are always faster than the write speed. Speeds are noted in MB/s. I think you've confused the size of the SSD with its speed - what did you use to test the read/write speed?
An issue reported by many is that the Macbook Pro seldom boots reliably from an optibay drive when selecting it as primary boot volume. Poor or bad SATA cables and the manufacture of the otpibay kit may be the reason.
By the way this is not iFixit customer service it is the volunteer help forum, so if you want to contact iFixit about a product please use the link at the bottom of the page.
If this answer is acceptable please remember to return and mark it.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorumlar:
Thanks for your response! To speed test I use "Blackmagic Disk Speed ​​Test". Currently speed SSD drive in Optibay is: read 253 Mb / s ; write 250 Mb / s.
Put in place the SSD to HDD slot is not possible, there I am already using 1.5 Tb Toshiba HDD - 12.5 mm
I read that my speed problem can be corrected by replacing the firmware SSD or replacement BIOS MacBook. Is this true? Is that even possible to do?
tarafından
Yorum Ekle
Yanıtını ekle
Konstantin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 5
Her zaman: 473
