Ana içeriğe geç
The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
Differentiate between Delphi & Panasonic LCS in PowerMac G5 Quad?
Seeking a replacement for my PowerMac G4 DP, I have decided on a PowerMac G5 2.7GHz DP Quad core. I have been informed that Delphi and Panasonic manufactured liquid cooling systems for this machine - Delphi's being dangerously unreliable. How can I tell which lcs is installed without dismantling the machine?
Bu iyi bir soru mu?
Puan 0
1 Yorum
This question was migrated from http://meta.ifixit.com/Answers.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
As I understand it the problematic models were the G5/2.5 DP (PCI-X) (June 2004) and G5/2.7 DP (PCI-X) (Early 2005)- aka PowerMac7,3- which were prone to leaking. So unless there's some sort of proof that the cooling system was replaced with the type from the late 05 avoid these models like the plague they were.
The G5 "Quad Core" (2.5) (Late 2005) - PowerMac11,2 - used a liquid cooling system that was substantially improved and better "sealed" to both reduce the likelihood of leaks and prevent leaks from damaging other system components.
If this answer is acceptable please remember to return and mark it.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
What coolant was used in the MAC PPC G5/2.5 DP (PCI-X) (June 2004)...
Anybody.... I understand that the coolant, in the ones that did not leak, could gell inside the radiators and then overheat. Like mine does, after about an hour. I have an ultrasonic cleaner big enough to hold the radiator assembly . I just need the coolant... and a disassembly/re-assembly procedure would be nice too.
tarafından
its called Dex-Cool by Prestone
tarafından
Yorum Ekle
Also Delphi made both coolers in the G5 Quad 2.5Ghz , Delphi for the single and Delphi/Cooligy for the double pumper. the Panasonic was only in a select few of the DP 2.7GHz machines. The Quad was only ever a 2.5GHz with two dual core CPUs.
Puan 0
Yorum Ekle
Yanıtını ekle
Lance Klein sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,407
