Ana içeriğe geç
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
307 Soru Tümünü görüntüle
Which SSD to choose for iMac 27" 2010
I don"t understand which SSD should I buy SATA 2 or 3? And what model would be the best?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
MacBook Pil Tamir Setleri
Başlangıç $69.99
Buy Now
Başlangıç $69.99
Buy Now
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Your system has a SATA 3 (6.0 Gb/s) interface for its HD and has a second port available (unused) which is also SATA 3.
While its a bit of work I would recommend doing the dual drive setup Vs swapping out your current HD for the SSD. Follow this IFIXIT guide Installing iMac Intel 27" EMC 2390 Dual Drive Kit.
If you are thinking on replacing your HD I would recommend going with a SSHD Vs a straight SSD. While its less work to replace the HD you will encounter issues with the thermal sensor with the SSD. Unlike the newer SSHD's from WD or Seagate resolve.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Martynas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 298
