Why isn't my volume button working?
My volume button isn't responding when I press the button. My tablet will not let me adjust the volume using the button on the side although I can change the volume manually on settings.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
This is a fairly common problem, and has two solutions to it.
First, try resetting the tablet. Occasionally the button becomes unresponsive, and you just have to reset the system and it works again. To Reset the system, you will enter System Settings and then Backup & Reset and you can press on Reset and the system will be resetting to the initial state.
If this does not work, you will have to replace the Digital Board inside your tablet. Follow the Lenovo IdeaTab A2109 Digital Board Replacement Guide.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 8,658
If it's anything like mine, you need to press the Fn button at the same time as F1 F2 F3
john.mulvey tarafından
Bcohen has the answer...atleast it worked for mine. Thank you
debralangager tarafından
