Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Audio Output Distortion on 3.5mm Headphone Jack
I've been using the machine everyday for many many years, especially for audio. One day I had the 3.5mm output plugged into a synthesizer to filter and mod the sound and some how some DC voltage leaked back into the mac and ever since then the port works, its just super noisy/distorted Whats even weirder is that the I get weird grounding noises/issues when I hook the mac DVI up to an external monitor. It gets amplified when I plug in the mag safe charger. These noises/issues can be heard thru the audio, even slightly when using a usb audio interface. Fortunately I have a parts unit to pull from. Has anyone seen this before? My first guess is to swap out the audio in/out board, but beyond that I dunno. If there are any board level repair guys who can give me advice. Thanks!
Update
So I did it and right when I got the audio board out I notice a blackened area, sure enough it toasted some resistors/caps, replaced the board and its all good! Thanks
Yanıtlandı! Cevabı görüntüleyin Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Not sure if changing out the audio board will fix this. Thats a good start.
Sounds like you blew one or more ground caps. The word 'Ground' here is a bit misleading we're really talking about the chassis frame. There are quite a few of these caps.
What happens when you use the optical link?
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Brian Fox sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 29
Her zaman: 2,629
