Early 2011 model, A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor.
716 Soru Tümünü görüntüle
MacBook Pro freezing every hour… Help please!
Hello,
I have a MacBook Pro 13", 2,3 GHz i5, A1278. It work fine from a month ago when it started to freeze completely after 1 hour working. I turn it on, it work well for 1 hour. After 1 hour exactly, it freeze completely and i only can shut it down by pressing on/off button.
I try to change RAM or to reinstall OS (because off 1 hour limitation working time i can't install last version), but no result...
Have you any idea from where come the problem and how i can solve it?
Thank you
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
First you may want to download a Fan & Temp monitoring application like Temperature Gauge Pro. With it you should be able to isolate out if your fan is not working or the temp of your system is running high.
If your temp is running high you'll need to look into a few different causes, like a app that is running wild (use Activity Monitor which is in your utilities folder) and you may need to look at your hard drives health. Try to find your system recovery disk if you got one with your system to boot your system from, then run Disk Utility. Or, create a bootable external HD (USB or better yet FireWire) or CD/DVD to run it from.
Let us know what you discover
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
JoseDC sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 2
Son 30 Gün: 10
Her zaman: 525
