Ana içeriğe geç
Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
228 Soru Tümünü görüntüle
Why am I getting a broken folder icon?
Just replaced the 1TB HD with a 3TB from an older Mac but was also running Snow Leopard.
After several tries, I continued to get the broken icon icon on attempted boot up.
When I put the original HD back it booted up fine and likewise with the 3TB back in the late 2007 20-iMac
Are there HDD incompatiblitiy issues?
They are both Seagate 7200.
Please advise as have 2 torn apart iMac and need them up and running.
thank you in advance
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
MacBook Pil Tamir Setleri
Başlangıç $69.99
Buy Now
Başlangıç $69.99
Buy Now
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
There may be OS compatibility issues if so this is a software, not hardware problem.
If you are seeing the circle with a slash through it the "system" is not (or files/kernels) are not compatible and a reinstall will correct it. If you are seeing the flashing "?" then there is no usable system folder (the old Mac may have been a PowerPC) or the HD is not mounting.
If this answer is acceptable please remember to return and mark it.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorumlar:
Thank you Machead3,
You are correct.
I shift+option R restarted and got the disk to load.
Thanks!!
tarafından
Yorum Ekle
Yanıtını ekle
Davejp sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 234
