Ana içeriğe geç
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1232 Soru Tümünü görüntüle
Why won't it turn on after battery replacement?
The 5C came to me with a shattered screen. I fixed the screen and it would not turn on. I tested the screen and it works on another 5C. I replaced the battery. The battery works on another 5C. I have tried holding the home button and the power button to reset it. That will not work. I have plugged into the computer. Will not charge. The working 5C worked on the computer. I tried plugging it into the wall. The wall charger worked on the working 5C. What else could possibly be wrong with this phone?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
6 Cevap
Filtre ölçütü:
Have you tried DFU mode and then itunes?
Try to hold the power and homebutton for a really long time (like a minute or so)
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Had this same problem and The phone is still just sitting
Puan 0
Yorum Ekle
If it was working before a screen replacement and now you have no power, I would be looking for a missing/damaged component on the board near the battery connector.
Puan 0
Yorum Ekle
I had a similar issue, our IPhone 5C will not turn on. I tested the battery and the screen on a second IPhone 5C and both worked. All connector are secure. I'm searching for an answer to this problem.
Puan 0
Yorum Ekle
Did anyone find an answer to the above question?
Puan 0
Yorum Ekle
I had the same issue, try DFU mode and restore with iTunes, after that the iPhone will turn on. But if you have the battery at 0% and turns off the issue can happen again.
Puan 0
Yorum Ekle
Yanıtını ekle
keldavis5 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 2,967
