Improving air flow for better temps
I would like to remove and mod the fan housing on my Radeon 6670 GPU to improve the air flow but don't know how to remove it. It's an ASUS model that has a large, plastic cover assembly over the entire fan mechanism.
The housing comes to 2 channels that appear to vent air out of the back of the card's bracket, but the housing is capped/closed off on the ends.
I believe that if I remove the housing and cut away the caps, more of the hot air could actually escape out the back of the case, which is vented in that spot.
Please help with the removal part, as I have a dremel tool and am fairly certain that I can do the mod once I figure out how to remove the fan assembly cover.
Thanks !
Bu iyi bir soru mu?
3 Yorum
Can you locate a good image of your model or take a picture so we can see which version you have and post it here.
Dan tarafından
lookie here: maybe this will help explain what I am talking about.....http://www.asus.com/media/global/product...
Rodney tarafından
OK, you have the newer version.
Dan tarafından
