Ana içeriğe geç
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
277 Soru Tümünü görüntüle
White 20" iMac: A1174 logic board physically the same as A1207?
So I've been working on a 2.0 Ghz Core Duo (T2500) iMac with a faulty ATi GPU producing artifacts on the screen and generally freezing the system. Since that stuff's soldered in, I'm going to have to replace the logic board.
I understand that there's a guide floating around this site about swapping the Core Duo CPU with a Core 2 Duo, since this model of iMac surprisingly uses a socketed CPU. That makes me curious; are the physical specifications of the board the exact same throughout the 2006 line of iMacs?
Namely, could I take a logic board from the late 2006 iMac and put it inside my early 2006 iMac chassis without a problem?
Since I have to replace the logic board anyway, I figure it would be nice to get Lion running on this old iMac at the very least.
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Dizüstü Bilgisayar Bataryaları
An easy fix for a big power boost.
Hemen Alışveriş Yapın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
See my answer on this here and then see if you have more questions:
Core Duo CPU upgrade to Core 2 Duo CPU?
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Internets sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 818
