Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
iPhone 5s home button works after repair but touch ID doesn't?
Hello,
Thank You for taking some time to help me with my problem, after replacing the screen on my iPhone 5S the home button works but touch id does not (the option has disappeared from settings).
Any help would be appreciated
Jordan
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
2 Yorum
And the cables don't appear to be damaged.
tarafından
Did you keep the same home button flex? Try a hard reset.
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
ive had this happen before aswell, try a soft reset, that worked for me (home button and power button till phone turns off)
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thank you for the suggestion, I've already tried that and a backup and restore.
tarafından
Yorum Ekle
my issue is the other way around. home button wont work but my touch id does. any ideas on how to fix this? also i have no service after the screen replacement as well.
Puan 0
Yorum Ekle
If your touch ID is not showing as an option in your settings then you damaged the home button flex cable. You will need to take the iPhone to Apple for a replacement.
Puan 0
Yorum Ekle
I did and I got a replacement iPhone at no extra cost.
Puan 0
Yorum Ekle
Yanıtını ekle
Jordan Baker sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 2,049
