Ana içeriğe geç
Mac hardware - anything that is made by Apple and plugs into an Apple device including external drives, power adapters, cables, converters etc.
1111 Soru Tümünü görüntüle
How to open up PowerBook G4 adapter
I have use PowerBook G4 but my pad bite the cable from the adapter. could anyone tell me how to open up the adapter.?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Why not just splice the cable? Why would you need to open it?
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
Done it and it works +
tarafından
Works for me + Ralph
tarafından
Yorum Ekle
It's machine pressed together when manufactured. This is so the is no chance a consumer can "accidentally" open and become harmed from the high voltage inside. I would just buy a new adapter. Even if you manage to open the adapter you raise the risk of a potential fire 10 fold. I really wouldn't attempt this unless you are VERY familiar with high voltage circuitry. I don't mean to discourage, but just make sure you understand the risks involved.
Best of luck!
-Varsity
Puan 1
Yorum Ekle
I've actually opened one of these adapters before- it's pretty difficult. You'll need a hammer and screwdriver/chisel to get the thing started. Just tap around the edges, and eventually the thing will crack. Be advised that you can in fact zap yourself (I did it multiple times), but there isn't really enough juice in there to hurt you, unless you leave the adapter plugged into a source of power.
It's really pretty difficult to fix any of the internals- everything is so tightly wedged together that you'll have a hard time getting things replaced. At any rate, if you're going to do any work on it, you should make sure you're good with electronic circuitry.
Puan 0
Yorum Ekle
Yanıtını ekle
elswinlpr sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,390
