Ana içeriğe geç
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Soru Tümünü görüntüle
Touch screen does not respond after glass replacement?
I cracked the glass on my phone. Functionality and everything worked fine. I decided that I was tired of the glass chipping away and went about changing the screen. Everything went well and the new glass was installed. The phone turned on and the screen looks great, but now the touching the screen there is no response. The back and home buttons worked. Voice command works. I removed the new glass and tried a new one with no change. What could this be? Any suggestions or tips would be great!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Take screen off and see does the touch work I have seen this problem before and it's to do with the glass being to high and not flush with the lcd you also need to use loca glue
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
it sounds like you did glass only? the digitizer is glued to the lcd and has to be replaced as one , it sounds like the digi was damaged in some way during the glass replacement, so i would try a new lcd/digi combo, sadly its much more expensive
Puan 1
Yorum Ekle
Yanıtını ekle
jcandjk1 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 155
