Apple released the MacBook Pro 15" Unibody with a new aluminum upper case machined from a single aluminum block.
2894 Soru Tümünü görüntüle
My MacBook turns off after startup
Yesterday I accidently spilled some alcohol on my macbook. I immediately turned it off and next day I oppened up macbook and clean everything with an 70% alcohol. I looked like there was no fluid on motherboard and other chips.
Then I tried to turn it on, it has booted up and after minute just blacked out. I tried to turn it on again, after logo it just blacked out again. I tried a several times sometimes it goes like the first time, but most of time it just shut down after logo.
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorumlar:
Start off by giving us the last four digits of your serial number. That will help us to properly identify your computer and its hardware.
tarafından
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
70% denatured alcohol still contains too much water... 90% or better is what you should use. Running it so soon after wetting may have shorted components. Examining with a magnifier looking for corrosion, burned or swollen components may point out such damage.
Replacing logic board components (soldering multi-layered logic boards) is a very advanced DIY project... generally I advise those who do not perform such tasks regularly (as in making a living repairing small electronics) turn that job over to a professional.
If this answer is acceptable please remember to return and mark it.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Klemen Humar sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 130
