Ana içeriğe geç
2001 Buick La Sabre Limited's RPM gauge drops to zero while driving?
My Buick's rpm gauge goes from working just fine to 0 in a matter of 20min. The car jolts a little bit when this happens and used to turn off completely while waiting at a red light/stop sign/idling. Can someone help me figure out whats going on?
Ive replaced the following:
Spark plugs/wires, fuel filter, serpentine belt, MAP sensor, Battery (brand new and 200$), gasket seals, oil change.
Thanks!
Bu iyi bir soru mu?
Puan 1
1 Yorum
A faulty crank sensor can cause rpm issues along with poor running conditions!
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
When it "goes to 0," does the engine shut off, or does the car mysteriously recover and keep on working? Could it be a faulty ignition switch?
My Accord used to just randomly turn off while in the middle of driving, and it took me a couple of months to figure out my ignition switch was bad. I replaced the ignition switch and things worked perfectly since!
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Can someone tell me why my 2000 Buick LeSabre speedometer not working RPM and Signal lights
Puan 0
1 Yorum:
Did you get the problem fixed
tarafından
Yorum Ekle
Yanıtını ekle
tarah sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 2,742
