Ana içeriğe geç
A 12.2-inch "prosumer" tablet released in February 2014. Powered by a custom version of Android 4.4 KitKat.
Replace cracked digitizer front screen
Hi, just tried to replace the front digitizer touchscreen on this device, however despite being able to source a digitizer it appears to be glued to the LCD via a clear double sided sheet and I have managed to destroy the LCD now :(
- so if anyone has any source for this part
On the plus side it is pretty easy to remove the rear cover for access to the battery, just clipped to the bezel so gentle pying of the bezel outwards removes this if you work methodically.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 6
3 Yorum
We're did you buy the replacement screen
tarafından
is the tape/glue only around the edges? Or is it entire glued down across the entire face of the lcd?
tarafından
According to some googling, you have to heat it up a bit because the digitizer is glued to the lcd and any forcing will destroy the lcd. Full lcd replacement costs about $200 and is the easier way to go.
tarafından
Yorum Ekle
10 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Honestly, please do not take this personal but before you destroying another LCD trying to fuse the two parts, I would take it to a pro. I am sure they would not mind answering your question about the best ways to do the repair. I know we don't at our store. If your bent on doing it your self the eBay ref above is a good place.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
These two parts are fuse just like all other galaxies. Will will have to heat the glass and separate the two. That is the only way to get the original digitizer. However you can always purchase another and fuse the two new piece together with LOCA or OCA Sheets.
Good luck!
Puan 2
Yorum Ekle
http://www.ebay.com/itm/Full-LCD-Display...
Here you go. where did you the digitizer by itself from?
Puan 0
Yorum Ekle
This is not an answer but a question... I'm about to change my screen over and have ordered a replacement which will arrive soon, so my question is, how to disassemble the Note Pro 12.2? Is it just a matter of removing the screen from the front in the same way you do for an iPad, or do you need to remove the device back? If the latter, what is the procedure?
Puan 0
9 Yorum:
where did you order the replacement screen from?
tarafından
tarafından
Did you get it fixed?
tarafından
Haven't received it yet. Still in the post. We live out in a rural area here so I'd expect it's still a few days away yet.
tarafından
Am also preparing to disassemble my tablet. Water damaged screen. Any tips would be appreciated.
tarafından
4 tane daha yorum göster
Yorum Ekle
I thinking 2 buy one but the digitizer is broken.touchpad is ok wath u think is posible to replace just glass or digitizer ???
Puan 0
4 Yorum:
After having gone through the incredibly tedious and time-intensive task of carefully heating and peeling the digitiser away from the LCD, I wouldn't bother doing this again. It's far easier to buy the digitiser and LCD as a complete assembly and just swap it out.
The digitiser is bonded to the ENTIRE surface of the LCD with a sheet of optically-clear adhesive, and it took me several hours to separate the two, then several hours more to bond the new digitiser with some 3M OCA sheet. Not worth the effort! Next time, I'll just swap the lot out and save me a couple of days.
tarafından
Ugh...I'm so confused. So just ordering the digitizer glass replacement isn't enough. It said there's no LCD display with. Do.I buy that seperate?
tarafından
Could the LCD turn on after removing the digitizer.. I was wanting to cheaply mines charged with image of battery but won't power on haven't order the digitizer. And yes it was a whole lot of mess trying to get it off.
tarafından
I just bought the note pro 12.2 for 30$ on offer up today. But the digitizer is completely spider webbed. What temp should I use with the heat gun?
tarafından
Yorum Ekle
P.s wher i can buy digitizer or glass ? Lcd is more expensiv.regards
Puan 0
1 Yorum:
I would just bye the full assembly.
tarafından
Yorum Ekle
You can replace the glass if the touch screen and LCD works although I wouldn't recommend attempting it if you have to ask
Puan 0
1 Yorum:
Totally agree. The glass is physically glued to the LCD panel and you can destroy the touch sensitive panel under the glass very easily. Just buy a whole new screen and all is well!
tarafından
Yorum Ekle
Any online videos on how to do this?
Puan 0
Yorum Ekle
I have the digitizer for sell $45 each + shipping it would depends where you are u can call 2064342553
Puan 0
3 Yorum:
I need a note 2 Verizon entire lcd assembly screen /
a note 3 lcd assembly digitizer and screen
and a tablet screen only FULL TOUCH SCREEN AND GRAPHICS ARE WORKING FLAWLESSLY FOR SOME TIME NOW TO THE GRACE OF GOD
also, if you do an asus transformer T100TQ -screen cracked and it has for the most part full sensititivty to touch just depends if glass is stting wrong way and I just gently turn upside down and get full touch back but a tin y spot seemed to arrive of color in lcd
I LOOKING FOR A DEAL FOR ALL PARTS
I can pay about $180 even 225 for the transformer screen which should cost only 35-50 max from my sources installed at 85 bc I have someone closeto me paying for it .. THEREFORE ...... I would just need invoice for greater of theone
tarafından
I bought the whole assembly for my galaxy tab pro 12.2 but when i put it all back together , all i get is a bunch of thick lines of different colors going down the screen...it does make touch sounds when i touch so i know the digitizer is working. i have also checked all the connections over and over again...what could be the problem
tarafından
You most likely cracked the lcd screen. They are super fragile and thin.
tarafından
Yorum Ekle
I just replaced a laptop digitizer successfully on an hp not problem...Its nice finding out that samsung SM-T520 is like totally glued to the lcd making my life a living !&&* right now, they didnt have to do that. My guess is that they are using el cheapo digital glass or someone sued them due to getting a glass fragment in the eye. I wish I had known this prior to ordering the digital glass but there was no mention in the ad for the glass that you would have to order both lcd and digitizer separately.
Puan 0
Yorum Ekle
Yanıtını ekle
Brian sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 20,410
