Ana içeriğe geç
Troubleshooting information and disassembly guides for garbage disposals.
5 Soru Tümünü görüntüle
Kenmore garbage disposal - No sound, just won't turn on
What if you turn on the disposal & there is no sound, no hum? It didn't break down while in use, & I have tried to fix it--pushed button on bottom, checked for blockages, flipped breaker--to no avail. I don't have the right sized allen wrench for the hole in the bottom, but seemed to move around a bit & sound like it's got water in it when I tried another tool in said hole. I want to fix it myself before calling the landlord. Thanks!
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I finally have the answer, it was a loose wire in the toggle switch housing. No idea why it came loose, vibration must have done it with use. Thank you for your suggestions.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
My Kenmore disposer works (the motor works) but it stopped spinning
tarafından
Yorum Ekle
Start Switch
On some models the stopper activates the start switch which is mounted into the upper housing of the garbage disposer. If the disposer won't turn or run at all the switch might be defective. The start switch can be checked for continuity and replaced if necessary.
Other Causes and Conditions
Wall Switch
If the garbage disposer won't turn or run at all the wall switch might be defective.
Non Serviceable Motor
If the garbage disposer won't turn or run at all the motor might be defective. The motor is not replaceable. If the motor is dead the disposer will have to be replaced.
Puan 1
1 Yorum:
Please tell us what worked.
tarafından
Yorum Ekle
Yanıtını ekle
Trace sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 35
Her zaman: 18,675
