Repair guides and support for all types of building materials.
193 Soru Tümünü görüntüle
need to remove hold down nail without damage to metal roof
How can I remove the hold down nails {to be replace with insulated screws[from the corrugated metal roof
without damaging the metal roof? is there a nail puller
that pulles straight up and not pried up.
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You may need to fashion a block of wood that conforms to the metal roof to spread the pressure of the hammer claw/crow bar base as you pry the nail.
I took two blocks of wood and two pieces of 1/4 steel placed across as short a distance as I could between the blocks. Then resting the hammer on the metal bar pulling the nails.
In my case I had raised over-lapping seams. If you have corrugated roofing that will be harder depending on where they nail it down.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
R Klein sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 15
Son 30 Gün: 54
Her zaman: 5,053
