Why isn't my Gateway NV55C turning on, but the charge light is on
Hi, my name is Nikita. My laptop has a few problems that are caused by some parts braking. I purchased the parts that I need, except for one. I don't know what it's called. I have a gateway nv55c laptop. It has a power button board that is connected to the motherboard through a cable. It's actually connected to a little particle that is about 2 centimeters by about 8 millimeters big. There was a short circuit or something, anyway, this part got burnt and is missing chunks of plastic that we're supposed to hold the power button cable. Any clues what it's called?
Bu iyi bir soru mu?
I have a similar problem. I found out I can boot the laptop if I remove the battery. Ibviouslt, that is a poor solution when you don't have an AC supply.
Do you have a diagram of that area of the laptop? I haven't found a reasonable manual to attempt even looking for the problem.
Dan Ceppa tarafından
