I replaced my dock assembly, why won't my iPhone connect to pc?
whenever i plugged in my iPhone the computer said usb device has malfunctioned. i "googled" around for solutions and found i needed a new dock assembly. so i purchased 1 and installed it but now my iPhone still wont connect help please
Bu iyi bir soru mu?
My iPhone would charge but there was no sound or lightning bolt when i plugged in in apart from 1 usb but i had the usb device not recognised problem. i changed the dock assembly and now ehen i plug it in there is no response from the iPhone or the pc. i havent checked if its charging should i let my battery drain to test for charging and then report back?
darby tarafından
you don't need to discharge it completely - only enough to see the difference
markus weiher tarafından
well when i plug the turned off iPhone to the pc it turns on but ill check for charge asap
darby tarafından
I discharged it an recharged it but when it's charging there no lightning bolt in the corner or "bleep" when i plug it in
darby tarafından
do you still have the old dock assembly ? i would put the old one back into the phone - maybe the new one is faulty!
