Ana içeriğe geç
Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
89 Soru Tümünü görüntüle
Soru Kapandı
PSP go headphone jack and speaker not working
I need help with my psp go. im not sure if there was a lose wiring or if i need to change something please help.
Please help!! My psp go has no sounds at all! There is no sounds in the speaker or in the headphones... I don't know what happened but the last thing I remember doing with it is playing MHFU and it died because of low battery.. I didn't charge it for a day and when I did charge it there was no more sound. Please help, I really want to get the sound back for my psp
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
There is a simple physical solution to this problem which is this
Just use the headphones with any software mine is 6. 61
And it will take two days for the software to pick up new updates for
The headphones .then the headphones will work fine automatically
tarafından
Yorum Ekle
6 Cevap
Filtre ölçütü:
this sounds like a software issue to me - so resetting it to the factory settings should help. but think abut it - resetting could delete everything on it
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
I think i did that already. i also formatted my 8gb m2 stick and the 14 gb storage it still didn't work
tarafından
Yorum Ekle
You need to wait for a new [System Software Update] and then install it to refresh your PSP's drivers or go into the Bluetooth settings and make sure it's not registered with a Bluetooth headset. If it is disable it.
Puan 0
Yorum Ekle
Hi,
First things first ;-
Clean out the headphone port with a cotten bud. Make sure the device is free from lint etc.
Test headphone is working.
Leave headphone plugged and attach to power supply via dock.
Check headphone.
If the headphone kicks in from either of these 2 tests it will be a blown fuse.
I am trying to source a replacement fuse but i cannot seem to find a suitable fuse so i have "bridged it" with some kynar wire.
Source: Loss of audio Output From Units speakers..
Hope this helps you out. In my experiance with all variations of the PSP it is rarely the softwares fault. The software may error but it will error due to a hardware issue.
Puan 0
Yorum Ekle
My headphones are FINE! but my PSP speakers arent working, and when i plug my headphones into my PSP, the system doesnt recognize them and it still wont make a sound :'(
Puan 0
Yorum Ekle
Happened to me, in EXACTLY the same way...
Puan 0
Yorum Ekle
---FIXED! --- I had this exact same problem and had just been using a bluetooth speaker(for months) since I didn't want to try to replace some tiny fuse on the motherboard like some of the forums suggested. Last night I left my psp open and on(which I never do) and the battery died completely. When I plugged in the charger an turned it back on, the speakers were working again. So, try letting your battery die completely, this maybe resets something and brings the speakers back. Worked for mine and it hasn't had sound(apart from bluetooth) for about a year.
Puan 0
1 Yorum:
its not workin'
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 10,256
