Ana içeriğe geç
Yeni nesil Nokia cihazlarının ilki – 1080p ekrana sahip ilk cihaz, dört çekirdekli Krait işlemciye sahip ilk cihaz
it's it possible to replace the front facing camera
it's it possible to replace the front facing camera?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
1 Yorum
I had the same question. The cable became damaged during a screen replacement and I found the replacement camera. Just not sure if its glued on or soldered or some other method. Any tips would be appreciated.
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Use can use these videos.Its really help me a lot for changing my camera.
https://www.youtube.com/watch?v=HQC2lZsB...
https://www.youtube.com/watch?v=qmNUl9Gh...
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Neither video is for a 1520. one is for a rear camera and one is for disassembling the 900. Unfortunately neither have a similar front facing camera to the 1520. Did you replace the front camera on a 1520? Thanks for any help you can provide.
tarafından
Yorum Ekle
Use 3m z conductive double sided band. 3M 9703
https://www.tedpella.com/TechNote_html/1...
Puan 1
3 Yorum:
Also do not forget to heat 70 degrees C. otherwise it will not work.
tarafından
Thank you!
But with this method. all the circuits of the camera you do not risk it to get in touch with each other?
tarafından
The tape is conductive only for Z direction(vertically). Side by side contacts will not be connected. I did it and worked.
tarafından
Yorum Ekle
Yeah, it's possible. Open the phone, find the broken front camera and replace it. But you must have bought the front camera replacement in advance.
Puan 0
3 Yorum:
Do you have a guide our video that could show me how before I buy the part?
tarafından
is there a guide or instructions. I can't tell if the front camera is glued down or soldered to the mainboard.
tarafından
I have the same problem I have my camera replacement but not how to do it
tarafından
Yorum Ekle
Hello,
I raise the subject, someone found a solution to replace the front camera?
Puan 0
Yorum Ekle
Yanıtını ekle
bob sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 2,409
